used lift needed
Posted 01 September 2010 - 03:57 PM
Posted 01 September 2010 - 06:45 PM
I know of a couple lifts that might fit your needs that could be had for relative low cost...
If your hill is small like that while you would have to have someone do the engineering, I'm sure you could probably, with supervision, do the lift install yourself. This would greatly lower the cost. Also with this short of lift the installation could be easily done in a summer. If you were able to get your permits and engineering done this winter for example, and locate a proper candidate for your used lift you could easily be running the season after...
Without knowing more about what you're thinking about it's hard to tell exactly what you are going to be looking at via cost and what not. If you have any other questions, comments etc don't hesitate to post again, email me at iceberg210@hotmail.com or call me at 801 809 3752.
Hope this information helps.
Posted 01 September 2010 - 08:02 PM
is that the hill Bob was snotubing on?? I might be mistaken though....,
From looking at a 1978 'skiing the midwest' book, it states 235' vertical, and it having 2 tbars and a chairlift...then. Is there really demand up there?
Lift
Try to buy used, less than 20 y/o, recently in service, well maintained, plan to replace the drive, some or all low voltage circuit, and do as much 'rebuilding' as possible on the ground.... and good luck finding. Also Check on your lift engineers past follys and success...my .02
Posted 02 September 2010 - 08:02 AM
Thanks for the info/advice. I would like to give you a call to discuss.
Posted 02 September 2010 - 08:07 AM
Lift
All that sounds correct. The t-bars are still there but the chairlift was removed/sold off about 5 plus years ago. Used would be our only option with us being a start-up non-profit. Demand? We think so. 45 minute drive from Fargo/Moorhead area with population of >150k.
Posted 02 September 2010 - 08:10 AM
Posted 03 September 2010 - 08:00 AM
Jeff Staley, on 02 September 2010 - 08:02 AM, said:
Call anytime, I'm currently in Montana and am driving south to Utah today so I might be out of range at various times but I'll give you a call back if you catch me between towers if you call today...
Posted 04 September 2010 - 06:36 PM
Also, I know Afton Alps has been known to have lifts and parts laying around. Almost everything they have is Hall from the early 70s. I believe all of their lifts (if sold used) would need a fair amount of investment to bring them up to a good condition. They are running original or minimally modified electricals on all of their lifts.
Best of luck in finding a lift that will fit your profile.
Posted 13 September 2010 - 03:14 PM
Thanks, Jeff
iceberg210, on 03 September 2010 - 08:00 AM, said:
Posted 15 September 2010 - 11:27 AM
Peter Pitcher, on 15 September 2010 - 11:12 AM, said:
I'd take Peter's word as fact if I were you - he is a veteran of the "transplant wars".
Posted 21 September 2010 - 10:51 AM
Thanks, Jeff
Posted 23 September 2010 - 04:50 AM
