Christmas Time - Forum overlay, winter 2009
Started by Bill, Dec 01 2009 09:30 PM
26 replies to this topic
#22
Posted 25 December 2010 - 06:30 AM
lastchair_44, on 25 December 2010 - 06:05 AM, said:
What was going on at Eagle Point?
Sick Poma.
Power outage / power resumption surge / blown VIGI and annunciator panels.
Anyone have a couple of these? Poma does not.
#24
#25
Posted 28 December 2010 - 07:59 PM
liftmech, on 28 December 2010 - 07:24 PM, said:
Uticor or Afficheur?
I'll have to check. I've never see either before. There are actually two of them - one in the machine room and one in the shack.
Each has 22 numbered LEDs (which work OK) and some signal processing between the LED anodes and a small board-mounted alphanumeric display. The display explains in words (when it works, I'm told) the same thing the LEDs are indicating. Their current problem is that no one has yet correlated the LEDs (and numbers) to the 22 circuits being monitored.
This post has been edited by Emax: 28 December 2010 - 08:06 PM
#26
Posted 20 January 2011 - 05:12 AM
Afficheur, then. There were two versions, one with 22 LEDs and one with 32. We should have two spares with 32 (for a detach, but it can be used on a fixed grip) from an upgrade several years ago. Yes, the LEDs correspond with the display, the idea being that the LEDS will give an indication even if the LCD display quits working.
#27
Posted 27 January 2011 - 12:26 PM
Thank you for your time. The fellow that needs them is Cliff Wordal / Eagle Point. Cell is 435 310 0445.
7 User(s) are reading this topic
0 members, 7 guests, 0 anonymous users
