Yah I remember seeing those things on two of the HSQ lifts at Big White...Interesting.
Announcement from Whistler Blackcomb
Started by Aussierob, Sep 15 2005 05:39 AM
107 replies to this topic
#102
Posted 11 April 2006 - 06:51 AM
Whistler, on Apr 9 2006, 11:02 PM, said:
Hey Rob, was the Excellerator Chair originally indended to be a bubbled chair? I wondered this because the armrests have those white plastic inserts that all the bubbled chairs do.
Excelerator was going to be a bubble chair, but not anymore.
If we go to an 8 pax on the Whistelr Express the theoretical capacity will be the same with more cabins on line. Actual capacity will increase with better loading efficiency. Cabins could be like these http://www.cwa.ch/en...om3_lwi_si.html
#103
Posted 13 April 2006 - 05:18 AM
edmontonguy, on Apr 9 2006, 11:20 PM, said:
Do they ever load those cabins with 10 passengers? it seems 8 is already a tight squeeze.
10 is an even tighter squeeze. After crossing the Black chair you want to sit down, but there's no room. I've done that a few times; part of the issue is there's no ski/board storage on the outside of the cabins.
New terminal equipment? What's being replaced, conveyor systems (chains with tires) or is there more?
#105
Posted 09 May 2006 - 07:24 PM
Rob, do you know what month construction will start? I want to make sure i dont miss it by going in June or the beginning of Sept
#106
Posted 09 May 2006 - 08:15 PM
Next year we are going to swap schedules, Whistler will close at the end of April, and the retro work will go on for 9 weeks. Blackcomb will stay open for the spring session.
