POMA PARTS NEEDED
Posted 26 December 2010 - 10:15 AM
A recent power surge has disabled two POMA LED / Alphanumeric fault display units - vintage 1985. These are the kind used in conjunction with the VIGI.
Poma has none of these and says they won't. Would like to get this system working while a complete replacement is being considered.
Contact Bud Fischer or PM Emax
Posted 26 December 2010 - 06:07 PM
Posted 29 December 2010 - 12:16 PM
iceberg210, on 26 December 2010 - 06:07 PM, said:
Tried calling, but could not get in touch with an appropriate person. The secretary seems to be in charge of all technical matters there.
Posted 29 August 2011 - 03:20 PM
This post has been edited by Nate214: 29 August 2011 - 03:23 PM
Posted 31 August 2011 - 08:33 PM
During the seventies and early eighties, tradition and a lot of pressure from certain European security-circuit Nazis forced us all to dream up clever schemes to find a "hole" in a 2-mile long series circuit. There was to be only one wire into which all towers (and in the case of VIGI, stop buttons, etc.) were connected in a string. The purists insisted that this was the only truly safe circuit - which is probably true... until the thing gets bypassed with a single jumper in a fit of Saturday afternoon frustration. In time, cooler heads prevailed and the far more practical one-circuit-per-function became the norm and built-in bypass was invented (credit YAN for this).
Among the "cute" locator schemes used were several variations on voltage dividers to ground (YAN and others), capacitance between two steel cables spaced 6 ft apart that spanned the lift line (Frey Equipment) and the French VIGI. All of these methods suffered the same fatal flaw: they could present the user with the WRONG information - which is far worse than NO information, if you think about it. An idiot can find a problem in a 20-tower circuit with no more than a volt meter if he's willing to climb five towers - but assure him that the problem is on tower nine, when it's actually on tower fifteen and he'll be there all day or longer.
VIGI, however, was quite clever - borrowing a technique long used by telephone companies to locate faults in their cables: time delay reflectometry. An electronic pulse is sent down the conductor - it reflects off the far (open) end and returns to the testing end. The propagation rate of this pulse is a known quantity in any particular conductor, so by timing the period between the initial pulse and its return to the point of origin (and dividing by 2), we can determine the distance between "home" and the open end of the wire. Each tower and pilot device would be a specific distance from the point of test - these distances would be recorded at the time of installation by actual test. The VIGI panel went a bit further than just offering distances though - it associated each distance with the alphanumeric name of the device located at that point in the circuit, displaying it on a small screen. Pretty neat trick for that period in time - or even for this one. Unfortunately - for POMA and the rest of us - resistances to ground on the safety line could foul the data and send you searching in the wrong place. Further, this neat piece of electronic magic did not care for either lightning strikes or ham-handed pseudo-techs attempting repairs - eventually, they all fail... and lately replacements cost $10k - if you can find one.
So yeah, it was not the best solution for the problem at hand - but it was a product dictated by its time and a damned fine piece of engineering.
This post has been edited by Emax: 31 August 2011 - 08:34 PM
Posted 02 September 2011 - 08:09 AM
As recently as two or three years ago I was using it to test my QuickBASIC knowledge with a board of 8 relays driven by a ULN2803, but the project was cancelled by the arrival of a new washing machine.
(Yeah, I've pimped my mom's old lean mean top-loading washer with a parallel port.)
No words from the Smithsonian so far. They're probably still wasting time on that boring shuttle.
Posted 02 September 2011 - 10:38 AM
Posted 02 September 2011 - 11:12 AM
Nate214, on 02 September 2011 - 10:38 AM, said:
I feel your pain. Why not implement something better? It would be worth the trouble.
