Most Lift Hours ?
Started by Aussierob, Mar 03 2005 07:03 PM
54 replies to this topic
Posted 03 March 2005 - 07:03 PM
I couldn't find this topic elsewhere so here is the question -
Which lift at your area has the most hours on it ?
At Blackcomb the Wizard has 45,000 (Doppel HSQ built in 1987)
At whistler the Village gondola has 54,000 (Poma 10 pass. gondola built in 1988)
Posted 04 March 2005 - 05:08 PM
I would be interested to know how many hours the River Run Gondola has on it since they have run night skiing for a long time and up until a few years ago skiing was open until 10 and the resturant was open even later. I talked to one of the mechanics up there who said it is usualy shut down for only 4-6 hours a night. Plus they also run summer activities too.
This post has been edited by poloxskier: 06 March 2005 - 01:21 PM
Posted 04 March 2005 - 08:30 PM
The resort i used to work at Australia has a 1960 POMA plater lift I don't know the number of hours or if it even had an hour meter but it's old, and still running. One of the lift inspectors commented on it being one of the oldest(if not the oldest) running lift in australia.
Posted 05 March 2005 - 05:01 AM
The Flyer ('86) has 27,900 total hours (I had to find the final reading on the old control panel and add it to the new one) and the Eagle ('89) has 29,000 (approximately). I would think Blackjack and Mountain Chief would be up there as well, bing a '73 and a '77 respectively, but they also missed a couple of seasons and don't run nearly as much as when they were I and J.
Posted 05 March 2005 - 09:16 PM
Here you go:
Manufacturer: Poma of France
Type: 4-CLD
Installed: 1986
Drive: top; ABB 1200 series (new 2003)
Tension: bottom; Volvo hydraulic (2 cylinders) 39,385 pounds force
Motor: 2- BBC 315L32, 676 HP each
Haul rope: 42mm 6x25 XIPS RLL SC (Seales)
Line gauge: 15'1"
Vertical: 1904'
Length: 9887'
Speed on line: 5.08 m/s (1000 FPM)
Speed in terminal: curently 1.04 m/s (205 FPM)
Towers: 35
Carriers: 203 'Falcon' (model 1986)
Capacity: 2400 PPH
Ride time: 9.887 minutes
Chair parking: full emergency rail top and bottom
Type: 4-CLD
Installed: 1986
Line gauge: 15'1"
Vertical: 1904'
Length: 9887'
Towers: 35
Capacity: 2400 PPH
#17
Posted 16 March 2005 - 09:33 AM
cbswygman, on Mar 15 2005, 02:02 PM, said:
At Bridger we have a 1964 Riblet that has run continuously since installation. I think they have an older one still running at Sun Valley.?.? Anyone ever heard of Truing riblet sheaves before installing them?
We figured the lift to have around 35,000 hours. 40 years of service.
Anyone tru a riblet sheave?
Posted 16 March 2005 - 02:38 PM
No, but I have found some with poorly installed bearing cups that cause a slight wobble once the sheave is installed. Perhaps that's what your referring to? If the cup isn't on the same axis as the sheave there really isn't anything you can do short of re-installing the cup. Of course, if it was put in off-kilter it probably raised up a lip in the hub, which is pretty easy in those soft aluminum sheaves.
35,000 hours is pretty good. They built those old Riblets bomber, didn't they? Baker has a 1952 that, while having had many parts upgraded, has been in service continuously. I don't know how many hours it has but I'm guessing it's approaching 50,000.
Zage- the Flyer's APU is a V-12.
Posted 05 May 2014 - 03:56 PM
The Cabriolet at Mountain Creek is probably the most heavily used lift I know of. It runs from anywhere from 7:30 to 8:30 am to anywhere from 9:15 to 10:15 pm depending on the day of the week during the ski season. It also runs weekends 8:30 to 6:15 from the first weekend in May to late June, then 8:30 am to 7:15 on weekends until Labor day and from 11:30 to 7:15 on weekdays. After Labor day, it runs Fridays from 10:30 am to 6:15 pm and Saturdays and Sundays from 8:30 am to 6:15 pm. These summer operations are for mountain biking and scenic rides. I don't know of any lift that runs as much, even the South Peak Express doesn't run till about 11:30 am midweek and it doesn't run at all during the summer, except when they are doing maintenance.
26 User(s) are reading this topic
0 members, 26 guests, 0 anonymous users
