Aerial Tramway Questions
Posted 27 October 2017 - 11:06 AM
The first couple questions.
1. Why do tram cars sway as they pass over the saddles on towers?
2. What is a track rope shoe?
Posted 30 October 2017 - 11:47 AM
4. How to track rope bollards work? I am confused on how/if they "unspool" or maintain stationary, and if track rope tension is also provided by the counterweight or if that is just for the haul rope.
5. On modern tram systems where the two cabins can run independent of each other, such as the new Roosevelt Island Tram, is the tram essential just two mechanical tram systems or can they share some components, like tensioning systems?
Posted 03 November 2017 - 08:12 AM
http://www.skilifts....showtopic=10910
1. Huge leaps in design technology in addressing swing damping in modern tramway - much like motocross shocks
3. Consider them like seatbelts - only used in extreme cases
4. By the term "bollard" do you mean " haul rope carrier" or "slack rope carrier" that is attached to the track rope?
5. They share the "drive" rope...
ISR has in-depth tramway information: http://de.isr.at/new...ierte-raeumung/
Posted 04 November 2017 - 05:34 PM
The Bollard end is fixed, it doesn't unspool. They are just there to privide enough friction to keep the track rope from going downhill. The other end is tensioned by counterweight or hydraulic rams, seperate from the haul rope, and separate to each side.
Posted 06 November 2017 - 11:50 AM
This post has been edited by Backbowlsbilly: 06 November 2017 - 11:55 AM
Posted 06 November 2017 - 07:30 PM
Posted 07 November 2017 - 10:01 AM
Ok I was thinking you meant a short row of pipes. Term is also called pollern (German for rope tie-off) or drum end connection. Most trams have bollards (short pipes or bumpers etc) at the terminal to stop the car if it swings excessively.
Notice the extra rope on reel next to the pollern...
To prevent fatigue of the track rope at tower saddles and terminals... at roughly a 10-year time interval a short distance of rope is released from reel then moved “around” the drum then “slid” downhill.
The “old” section is removed at the bottom and the “newer” rope is reattached to the counterweight. The technical term for this process is called “rope slipping” or slipped as the rope slips through the shoe/saddles.
Picture of Squaw’s drum ends, notice the towers in the background... this is one of Yan’s first chairlifts (Links). Drum ends or pollers at Squaw are now under a “decorative” cover.
The haulrope transmits power to accelerate the load and also can provide braking.
For needed traction the haulrope must contact the bullwheel with a large (long) surface to establish the necessary friction; a 180 degree wrap or better helps successfully transmit those forces.
If you look closely you can see the rather large caliper brake on the bullwheel flange...
Posted 08 November 2017 - 05:41 PM
Posted 13 November 2017 - 11:29 AM
An additional question is why would counterweights need to be damped, rather than just be suspended in the counterweight pit?
This post has been edited by Backbowlsbilly: 13 November 2017 - 11:36 AM
Posted 15 November 2017 - 11:24 AM
Posted 01 December 2017 - 12:12 PM
#14
Posted 04 December 2017 - 12:05 PM
Sorry for any confusion or wording mixups, please feel free to correct anything that was misused.
Edit: Why would a different diameter rope be used for the haul rope (lead through the drive) and counter rope (lead through the counterweight)? I think that is the piece of information that made drum anchoring seem oddly unnecessary that I was missing before, it would be necessary if there was slightly different diameter ropes connecting at it.
This post has been edited by Backbowlsbilly: 07 December 2017 - 11:33 AM
Posted 08 December 2017 - 08:46 AM
Roosevelt rope diagram courtesy via our good friends at remontees-mecaniques.net then via Poma...
Posted 08 December 2017 - 09:12 AM
TR = Track rope
HR = Haul rope
Cr = Car carriage
The term carriage is sometimes problematic as it can be used to denote the carriage for the haulrope tension system and track rope tension system.
Blue square is one area that you can have a haulrope carriage...
Getting back to Billy’s questions
The haulrope attachment at the car carriage has a lot to do with track slope, passenger capacity, oversight codes, track rope brakes and newer rope clamp designs. Full socketed connections have full rope strength capacity and are (relatively) maintenance free but are more difficult to place exactly. Shown below are weaves, clamps and socketed connections.
A track rope is a group of “locked" wires that can only be “bent” a certain degree – they are usually socketed to a “twisted wire” rope that has more flex ability as it passes over the deviation sheave before the vertical counter weight path. – See red blob in upper picture for this connection. The short twisted rope holding the counterweight is called the counterweight rope. It is slightly bigger diameter because the individual wires are not as tightly packed together as a locked wire or locked coil rope which are very close to solid rods of steel. Both have similar breaking and fatigue strengths.
Billy time to buy the book :)
Number of downloads: 93 -
Number of downloads: 89 -
#17
Posted 12 December 2017 - 10:45 AM
This video shows many tram aspects and gives a “voice-over” interview with Austen Edwards the manager for the Portland tramway.
There is a nice view of the rope dynamics in the upper span (shown in fast-motion) that isn’t as apparent when you ride the tram (starts at 1:19).
Haulrope carriage system can be seen at :48 – blue device is a hydraulic dampener to control the counterweight “carriage” movement.
Yellow numbers show the carriage position (some movement of the carriage can also be seen).
Speaking with Garaventa engineers they are quite proud of this hidden device.
7 User(s) are reading this topic
0 members, 7 guests, 0 anonymous users
