This post has been edited by julestheshiba: 10 April 2016 - 04:07 PM
Drive Shaft Lifts vs Above Drive
Posted 03 April 2016 - 03:49 PM
http://www.skilifts....lt&fromsearch=1
Posted 03 April 2016 - 04:31 PM
It's worth reading though for one main reason ; someone brought up that the overhead drive has the ability to have drive & tension at the same station. That's good if you don't have the money to run wiring to the top but want bottom tensioning I suppose. But if you do have the money to do so, I believe that pulling (top drive) is better than pushing (bottom drive) and something that escapes me a.t.m about bottom tensioning is also better than top.
Posted 03 April 2016 - 09:12 PM
You can't shoot pool with a rope. A bottom drive pulls on the light side which in turn pulls on the heavy side via the return bullwheel.
Posted 04 April 2016 - 05:48 AM
Yes I just forgot what they were called
-Will
Posted 08 April 2016 - 05:35 PM
The original Adirondack Express from Gore Mountain (1984 VonRoll high speed triple) had an overhead drive where the whole unit was mounted on the tension carriage, allowing for both to be at the bottom. It was integrated and not a separate fixed grip drive terminal. The lift was removed after the 2013-2014 season and scrapped soon after. It was replaced by a Leitner Poma HSQ for the 14-15 season.
This post has been edited by snoloco: 08 April 2016 - 05:36 PM
Posted 09 April 2016 - 09:02 AM
barnstormer, on 09 April 2016 - 06:05 AM, said:
Heron built a few drive/tension terminals that are in vaults. Two examples are "B" lift at Bretton Woods, NH and the Red chair at Magic Mountain, VT.
The original E Lift at Copper Mountain, CO (1972) was of the same design. Bottom Drive / Tension in a vault.
Posted 09 April 2016 - 12:48 PM
I think most heron poma lifts have vault drives.
-Will
#17
Posted 09 April 2016 - 05:33 PM
Posted 09 April 2016 - 05:36 PM
NHskier13, on 03 April 2016 - 09:29 AM, said:
However, the main reason why vaults were phased out ( I think ) would be space ;
They weren't phased out. Both gondolas at Snowbasin (1997-1998 vintage) are vault drives. See my post above for more details as to why one would need a vault.
Posted 10 April 2016 - 12:17 PM
The Falcon gondola terminals usually had vault drives, but Stowe has an overhead bottom drive on their gondola. It's also part of a larger building, so maybe that gave them the extra space for an overhead drive. The Whistler Village Gondola, as well as the gondolas at Stratton and Aspen use this terminal with a vault drive.
Posted 10 April 2016 - 04:06 PM
liftmech, on 09 April 2016 - 05:33 PM, said:
Yes that is what I meant I will change the question. Why I thought it would be slower would be due to torque being lost in the vault shaft and the friction from the weight of the bullwheel on the gearbox and everything it is touching.
This post has been edited by julestheshiba: 10 April 2016 - 04:10 PM
-Will
